E39 A/C issue
theblackbeast
One fine morning my a/c was not cold. Found the compressor clutch is not kicking in. Thanks to bro 525i, checked the CCU is fine but we found out the 1 month old recon electric fan has kaput. All other fuse, relays, sensors relating to a/c is in good condition. Direct DC to compressor should its able to kick in the clutch and a/c is cold. Anyone had this symptoms before, any recommend workshop who has the diagnosis tool and good knowledge on E39 double vanos electronics.cheers..........
naidu jln gasing in pj comes recommended.....search the treads for contact
Thanks Moots , Pussy - visited Naidu but no luck getting it fixed.
Diagnosis done
Reset at bat terminal
checked sensor internal + fuse
compressor pressure
Than drove to Optimum 1 for compu check
Diagnosis Done
check all sensors + fuse
clear all fault codes
direct connection to compressor from compu - worked well
they dont deal with a/c so he is not sure, refer me to someone in TTDI. That guy says because my electric fan is not working therefore the compressor is not working. But the checked there is no power at the electric fan wire nor the compressor wire.
Optimum One later suggested it could be pressure switch.
Has anyone experience this symptoms before? I have requested a air cond workshop to source for 2nd-hand preassure switch to test. Anyone have any other recommendation?
Thanks guys!
Hi TBB,
Try going to Optimum u can see Ah Fai or Jason, if u need good aircon guy familiar with BMW u can try this guy Brian Lee 016-6638500 he located in a tyre shop at Tmn Tun, many BMW guys go see him reasonable even Ingress Auto send their client with aircon issue to him.
I drive E39 2003 M54 and find him good.
Cheers
Siva
siva@e39;823504 said:
Hi TBB,
Cheers
Siva
Hi Siva, Jason from Optimum checked but he said not sure also as this is a/c related. Okay let me try the contact you have provided.
Many thanks bro,
cheers
hi tbb,
Give itt a shot, bro so far two of my friends using E39 have sent it their UDM said they where happy with this guy.
U can mention my name just Siva with E39 blue colour he will know bro.
Hope your issue can be solved do buzz me 019 2622112 we have TT and chhat regarding our UDM i am always near Damansara Perdana or Tmn Tun area.
Cheers
Siva
Wah... got e39 tt around tmn tun area? No wonder I keep seeing nicely done e39's all the time around bu/ttdi.
Sent from my GT-I9300 using Tapatalk 2
we can TT just for fun hang out solve issues regarding UDM share problems..................cheers
siva@e39;823615 said:
hi tbb,
Cheers
Siva
Bro, last Friday left car at Brian's place - he sent my beast to another workshop in Kota Damansara. He had this OTC diagnosis laptop and surprisingly it was able to detect 3 issues with a/c.
Inside Cabin
1. Temp switch
2. Climate Control
Engine
1. Pressure Switch
Sensor + Switch has been replaced - error code is no more. However the climate control unit he received from chop shop did not work :smokin:
I still think this can be repaired - let me browse this. Worst case will need sifu 525i to help on ebay.
Will keep the update rolling.
Inside Cabin
1. Temp switch
2. Climate Control
Engine
1. Pressure Switch
Thats good TBB, hopefully u can source out climate control unit try looking into mudah.com i did see some units for sale.
Cheers
siva@e39;825382 said:
TBB,
How the ride AC fixed already............all good.
Cheers
Have not yet bro......... no one can find out what is the issue of a/c compressor clutch not kicking in. Swapped the climate control unit with another BMWCM member to test (same model) its not working. My unit out in his car - no issues. so so blur ...........:stupid:
I also have run out possible idea whats the issue TBB.
Take care
Is it clutch not kicking in meaning not current to AC compressor ? All relays are ok ? You suppose to find a wireman to check for this issue.
Hi TB...
Is your air cond issue solved...
Check pm please...
weeks ago the place where I changes the compressor TnT Sunway did bring in a wireman to check - but he was not able to find issues with relays / fuse etc.
Volvos525i;826324 said:
Hi TB...
Check pm please...
Issue not solved yet bro.......beast is taking a break away from the busy highway. Just checked your PM....thanks!
