Originally posted by teejay@Jan 20 2006, 10:58 PM
my turn......
jules LISTEN THIS TIME.........!!!!!
brakes function in a system
1. servo- vaccum from engine,is your engine within the vaccum specs?
2. linkage-is the linkage within specs,i.e. position
3. master cylinder- has it been bled ? how old are they? are inner seals worn?
4. brake fluid- when was it changed?
5. calipers - when was the seales changed? was it bled recently?
6. rotors - what's its thickness? within specs? any signs of glazing?
7. pads - what type, what kind, any signs of glazing?
any fault in any components will deteriorate the brakes performance
most important technique that is not adhered to is the proper beddding in of the pads with the rotors, if done proper ,brakes will bite, if not, it will suffer for the rest of its lifetime
since master TJ is replyin...I better respond
1. since u know, what is the vacuum specs? in kg/m sq.
2. linkage will be standard & I am not aware you have possibilities to adjust this.
3. master cylinder are bleed, no idea abt inner seals condition.
4. fluid - of course they r changed.
5. seals are fine and bleed when item 4 done.
6. discs are NEW, 22mm Mr TJ, sir! no glazing
7. Pagid Fast Road pads NEW - I personally removed the LHS pads and they look all ok - inner and outer ones.
You reading on? good.
Actually - if you all read my ori post carefully, I solved my issues and have the solution. Thanks anyway for your suggestions and checking the above (TJ), changing the servo (ichiwan) and offer to test ur car (fab). Skar - my cousin, you know who - told me that when the e30 first came out, they had many complaints from the NEW owners. I repeat NEW owners. A upgraded vacuum kit was then available shortly.....so maybe these were for the early batch 323/320.
I have personally driven other e30s and found their brakes weak too - at least in my expectation of a good brake. ( all disc/disc setup ) Actually all except one, which is the set-up I have now.
The intention of my thread is to see if I am wrong in my expectation and so far, most of you agree with my assessment. ( weak brakes...)
I will shortly post up the pic of my set up - to SHARE with you all. Anyhow, I assume Master TJ voted ok for his monster Hartge 327 brakes and Skar too....
