aidilj
Official Member
- Jul 3, 2010
- 2,291
My unit is one of the dumbed-down trim that doesn't come with board computer stalk. Thanks to bro Zidee, the stalk was acquired.After installation of the stalk itself, the feature needs to be enabled through programming. I'm using DIS for programming, so if you don't have one, you might want to visit the mechanic for it.The car is an E46 N42 MY2002.Remove battery to not raise airbag alarm after installation
I'm on 4 spoke steering, remove two torx screws on each side to remove airbag and steering buttons
off
Remove bolt with wrench
Note the steering center marking
Remove top clip
Remove bottom clip
Pry open console and remove four torx screws to release slip ring
Three connectors to the slip ring
The turn signal connector already have four wires, the non-BC stalk uses only three
Pin difference between BC (left) and non-BC (right) stalkhttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/IMG_3069_G.jpgRemove the non-BC stalk, install the BC stalk and reverse installation. Now to enable the BC button at the stalk.Fire up DIS and click on Coding/Programhttp://i791.photobucket.com/albums/yy197/aidilj/ihka/3.pngSelect ZCS/FA codinghttp://i791.photobucket.com/albums/yy197/aidilj/ihka/15.pngWarningshttp://i791.photobucket.com/albums/yy197/aidilj/diagnostic/7.pnghttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/2.pngChoose E46http://i791.photobucket.com/albums/yy197/aidilj/board-computer/3.pngChoose retrofithttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/4.pngWarningshttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/5.pngOn-board computerhttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/6.pnghttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/7.pnghttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/8.pnghttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/9.pnghttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/10_G.pnghttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/11.pngBefore and after in INPABC function offhttp://i791.photobucket.com/albums/yy197/aidilj/diagnostic/bcoff_G.pngBC function onhttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/12_G.pngBC functionclockhttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/IMG_3071_G.jpgoutside temperaturehttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/IMG_3072_G.jpgaverage consumptionhttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/IMG_3073_G.jpgdistance to empty (cruise distance)http://i791.photobucket.com/albums/yy197/aidilj/board-computer/IMG_3074_G.jpgaverage speedhttp://i791.photobucket.com/albums/yy197/aidilj/board-computer/IMG_3075_G.jpgCheersAidil
