Dip Beam goes cuckoo
CAJ19
Help sifus.......! My E34 right low beam was not working. Checked the fuse for both left and right, all in order. Use a multimeter to test the voltage at the bulb terminals, - 9.78volts???????? The bulb was OK. Guess must be loose connections. Traced all the way to fuse box, still could not find and connections. Finally, hook-up a relay switch tapping from the pilot light(Small light). Walla, light was OK. Then the bulb on the left blew.....WTF@#%& Tested for voltage, initially, 10.7volts, tested the second time, nothing. What to do????? Hook-up parallel to the right lamp relay. Now both the low beams are working fine but the indicator keep coming on showhing "DIP BEAM" I've already connected the original terminals to the bulb to provide constant connectivity, BUT the indicator still cums ON. HELP,HELP.
