source - http://forums.bimmerforums.com/forum/showthread.php?t=1498837Don't know about the rest of the swap but you have a partial drive by wire system in your M52TU, the M54 is full drive by wire. Your throttle body, cable to throttle body and lack of a pedal sensor is a different setup than the M54 cars.
At the least I'd think you'd need the above parts, the engine wiring harness, the ECU/DME and then you'd have to check all the pin-outs on the Siemens MS42.0 DME System you have versus the Siemens MS 43.0 DME system the M54 engine has.
I am assuming if you swap DME/ECU you'll also need things like the general control module and/or others at at the least need to recode them.
You might find more info on autoenginuity or INPA/Ediabas forums w/r/t re-coding, coding, setting adaption values, etc...
Check out the differences in the Bentley manual or stop by some time on a weekend and I'll show you.
* if it were mine, I'd throw another M52TU 2.8L motor in there for less "hassle" factor.
vincent;632452 said:look for this forum name call "Loafer" he will let you know how ...
John_Smith;632570 said:Hope this helps: https://rapidshare.com/files/460184205/Engines.pdf
Very detailed explanation on the difference between the 2.
bmw7833;632724 said:I have the complete file for m52tu and m54, check your email bro.
bimmerholic;632729 said:Bro, can email me the file too....Thanks ya.
bmw7833;632731 said:Sent bro..
ramsing;632834 said:prez of hamsap bmw club, y la u suddenly gatal? u want to change engine? not worth the $$$ for that little extra, which is negligible. if you want the m54 exp, then u need to buy a car that comes from factory with m54. if u want to get more power from m52tu, then there's many ways to undress the pussy. u can ask pussy, he's been undressed many times when he was drunk, sometimes by females but mostly by males.
most impt, what u looking first?
initialM;632885 said:hahaha as always my butt always itchy lar. Since cant sell my E46 328, been thinkin to do some underwear project.
Not pussy underwear la. he redy love the 8 pistons. he said the more the merrier. Maybe I should stick 2.8 ponnies la
loafer;632915 said:Stroke la.....I got M54B30 stroker kit if you want :65:
Would be a waste of money if you buy the whole M54B30 engine, not cheap.
initialM;632935 said:Aduh ini poison xbole tahan. PM me details bro. If possible I also dun wan engine conversion or mod. Wanna keep ori as possible. Thats why I'm sellling the 328 to go for 330ci if possible hehehehe
ramsing;633042 said:lol...it all goes back to what u expecting. if u expecting miracles after stroking to 3.0/3.2, then i can tell u now, u better off go zon regency for one year and spend the money there.
unless ur current engine is totally worn down and in need of overhaul, then stroker might be an option as you're already opening up. if u want power, only way is to push air inside, supercharger or turbo. supercharger is easiest, plug n play. good power output, but autobox might end up premature ejaculation if u always keep stroking it![]()
unless u're a dark sith master stroker like feizald'zul, then u have to learn the dark stroking techniques from him on how to keep the gbox intact.
but if u want 500whp daily driver, then this discussion will be taken offline, preferably somewhere with nice hot water pools and they're always glad u cum!!![]()
