"Check" light on
crusher
This morning a light came on , it says "Check". After few seconds went away. I don't think I'm low on oil or coolant, will check later. Any idea what this means?
Usually when the "Check" light comes on you can see the fault displayed on your OBC.
Not sure if it's for all faults though but most faults I believe will be shown there.
My OBC led/ights are not working anymore so can't see anything. Do you think I can still drive my car until i can get it to a workshop?
Well it doesn't seem like you have much of a choice. I hope your workshop isn't too far away.
oh no.. what happened to my ex? :(
Does the engine sputter or have rough idling? If yes. Best to tow. Once on MODIC, you'll know what's wrong. Most likely a sensor.
Oh hold on.. It's not the engine check light, right? Most likely it's the rear brake light (right side). That circuit is kinda old and tends to lose it's conductivity.
The OBC works but the display is slightly off. What you do is, press the OBC display and run your fingers along the display. You can make out what it says.... normally I always get "Check Brake Light"... If this is so, don't worry la. Can drive, what you do is just jiggle the right side brake bulb holder a bit. After re-starting the car, it should go away.
want to get the anti-dote for these bug which KILL the OBC, i sale it at RM5,000.00 share for 100 people/E36 owner for RM50 per person;
soo,soo, soo damn cheap already.., that bug not only affect OBC.., other too...., debug it now before it start to KILL
DIY capable by any E36 owner to debug it...,
look for it by yourself, if you all did not trust me at all.
i am not the bug designer, it was hardwork to find/dig it out..
i suspect it had been intergrated into other BMW as well ???, no idea who design it??
real-real-real DIRTY work... for dirty money,????? (CKD version?/ JAPANese version?)
sorry for those E46, or other model... :34:,
much more complex system...? much more bug???
contact me tru..
email to jokeracts@hotmail.com,
my 18 buttons OBC currently working very well, AWESOME!! :34:
how many button for you OBC V?
no need to any workshop, just check the coolant level/washer level by yourself,
top-up, if not check the sensor connection :34:
other, maybe there was BUG?????
that bug will keep kill the OBC even new OBC was installed... soo damn...
that was not PRO.....:34:
joker, watch it. i think i know more about that car than you do. suck a joker.
it seem normal problem for E36. I've facing this situation for about 6 month. unsolved problem. My OBC always
1) Washer fluid low
2) Coolant fluid low
3) 1 Brake light failure.
Any idea to overcome this problem
soo what is the next thing will happend??, blown engine/gearbox?,
the car blow out? :34:,
1) Washer fluid low
if all the sensor was okay, bulb okay, connector okay, coolant level okay,
soo, maybe it need to XXXXX secret... if still cannot work;
then it could be the BUG ,
join us to share the dirty secret of E36 :top:
call me for technical asistance, 0168568563, or just sms.
or email to jokeracts@hotmail.com,
Bro, I think you are wrong to think that all problem are bug related.
It sad to have people like you who drive an UDM.
Honestly, its people like YOU who give UDM a bad name.
please sell your car and refrain from posting on this forum.
1) Washer fluid low
It is a well known problem with E36 to have bad contact for the brake and night driving light.
if you were to study the rear light casing, the contact on the bulb holder is spring load clip. They have a tendency to loose it shape due to the constant vibration.
A clear sign is oxidation or slightly scour or burnt mark. Just clean the contact by sanding it down with a sand paper and push the two clip up. It should solved your problem.
yeah, ranting like a lunatic does not help as well..
And for your information, this method work whether you believe it or not..
damn, only the bug designer will say such word..:34:,
coz they fear the dirty secret being disclose..:34:
Thanks affan, followed your instructions and could just make out the "Check brake light". Anyway, problem did not re-appear and I guess you're right
