bmw navi tv
drkoh
How can unlocking of the TV function while driving?because can not Watch TV while driving.thank you!
Yes you can unlock the safety function that disallows TV function while driving. You would need to get a new wire harness & decode it. There are quite a number of BMW that has done this. Not cheap tho. 1k plus & can be done at Obermaier.
Where is the place, any contact or addresses?
My TV tuner has an AUx channel (shown on the screen). Do you think I can add a DVDV player there?
Obermaier Motor Sports
No. 12, Jln Suppiah Pillay, 51200 Kuala Lumpur, Wilayah Persekutuan
Phone: 03-4043 1498
this is from a forum
Watch TV / Videotext during driving
This works on all BMW 5/7 Series with the Mark I Navigation System (the one with the male voice).
On Mark II (the newer version with the female voice) you have to use "brightness" instead of
contrast for TV and "color" instead of brightness for videotext to get the trick to work.
This works on the latest 99 7-series models as well. This does not appear to work for the latest BMWs
sold in Europe (2000 onward, 3/5/7 series). The software updates for latest navigation CD-ROM's do not
appear to affect or disable this trick.
set ignition to pos. II
enter TV mode
enter "settings"
enter "contrast"
when the green contrast bar is visible, push the knob and keep it pressed
turn ignition off (keep button pressed!)
wait 8-10 seconds (timing must be accurate!)
release the knob
turn on ignition again
Now the TV will operate while the car is in motion, though you certainly should leave that to your
passengers only while driving. To watch videotext use the same procedure as above, but choose
"brightness" instead of "contrast"
