l8nite
- Aug 18, 2012
- 53
hello to all.firstly, i am sorry if this post not suitable to park here. if not, mod please transfer to new location.i just bought bmw e36. the previous owner just change the engine to 2.5cc single vanos.however, there are several problem.the fc really make me scared to drive that car. from kuala lumpur to seri manjung already rm200! believe it!the other problem is the engine idle. when i start the car in the morning, the idle was good. but after i drive a few kilometer, the idle was not accurate. if i switch on aircond, the idle was ok. the previous owner said, it just idle valve. just clean it and it will ok. is that true?last problem, the radiator got small hole at drain path so the temp sometimes will increase if i not topup the water. so is there a others ways to cover that hole or to change new radiator? if change new, how much it cost?thank you to all.hopefully can got the advise and answer from the expert.
