hi guys..just wanna ask what is the diff ratio of std 320i e30? is it 4.10?
what is the best diff for E30? is it 325i?
M40B18/M10B18 uses 3.9.1 or 4.1.0
M20B20 uses 3.7.3 or 3.9.1
M20B23 uses 3.7.3 or 3.9.1
M20B25 uses 3.4.5 or 3.7.3
The ratios differ among the different markets and regions
Drive any BMW in anger, you will discover it's SOUL!
depends on ur style of driving i guess.
have tried both 3.91 & 3.73 open diff (non LSD both)
3.73 = better highway cruising speed (less rpm at high speeds)
3.91 = better acceleration , much higher rpm @ highspeeds if compared to the 3.91 diff.
of coz driving with a 3.91 diff consumes bit more petrol but u gain better acceleration .
i heard 4.10 is the best for acceleration , but i may be wrong.
hope this helps.
What is diff ratio?
Loving What I Drive & What I Do Best
gear ratio = The gear ratio is the relationship between the number of teeth on two gears that are meshed or two sprockets connected with a common roller chain, or the circumferences of two pulleys connected with a drive belt.
differential ratio is different from gear ratio. But the idea is the same.
To simplify:
If differential ratio is 4.0:1
Your driveshaft needs to turn 4 revolutions , to turn 1 rotation on the wheel.
Hope this help.
~May the boost be with you~
Parc fermé : E36 , 67mini | Wanted: 240R
lol..i got confused. thanks 4 clearing that up
I understand that... THanks..
thanx guys for the info...i wish to have e30 diff with lsd...gonna drift it!
